Ôîðóì: MS ACCESSVBVBA MS OfficeMS SQL server
Íîâûå ñîîáùåíèÿ: 0000
Ôîðóì: MS ACCESS
Âîïðîñû ñâÿçàííûå ñ MS ACCESS
Îáíîâèòü âèçèòêó
Ó÷àñòíèêè «Online»
Âñå ó÷àñòíèêè
Äîáðîãî âðåìåíè ñóòîê, Ïîñåòèòåëü!
âèä ôîðóìà:
Ëèíåéíûé ôîðóì Ñòðóêòóðíûé ôîðóì
òåìà: Êîíòðîëû
 àâòîð: ÷àñ   (29.01.2007 â 10:33)   ëè÷íîå ñîîáùåíèå
Õî÷åòñÿ â öèêëå îáðàáîòàòü ñðàçó íåñêîëüêî ïîëåé
ñ èìåíàìè S1,S2,S3........
Dim kon As Control
èëè
Dim kon As Field
êàê áû òóò îáîéòèñü îäíîé ñòðî÷êîé â öèêëå
kon = "s" & "1"
  Îòâåòèòü
 àâòîð: Explorer   (29.01.2007 â 10:37)   ëè÷íîå ñîîáùåíèå
for each ctl in me.controls
<as example>
if ctl.type = sometype
if left(ct.name,n) = somestrig
  Îòâåòèòü
 àâòîð: Bellerofont   (29.01.2007 â 10:46)   ëè÷íîå ñîîáùåíèå
For i = 1 To 23
    Me.Controls("s" & i).Enabled = False
Next
  Îòâåòèòü
 àâòîð: Explorer   (29.01.2007 â 10:53)   ëè÷íîå ñîîáùåíèå
äà, òàê ñäåëàíî â ñòàíäàðòíîì ñâè÷áîðäå, ýòî äîñòàòî÷íî ýôôåêòèâíîå ðåøåíèå, õîðîøèé ïðèìåð.
åäèíñòâåííûé ìèíóñ - íóæíî çàäàâàòü êîëè÷åñòâî íóìåðîâàííûõ ýëåìåíòîâ
    For intOption = 2 To conNumButtons
        Me("Option" & intOption).Visible = False
        Me("OptionLabel" & intOption).Visible = False
    Next intOption
  Îòâåòèòü
 àâòîð: ÷àñ   (29.01.2007 â 11:29)   ëè÷íîå ñîîáùåíèå
Ñïàñèáî âñåì,
âîò ÷òî ïîëó÷èëîñü ïîñëå ïðèìåíåíèÿ Âàøèõ ñîâåòîâ...
Dim ctl As Control
Dim f As Integer
f = 1
For Each ctl In Me.Controls
If ctl.Name = "s" & f Then
ctl.Width = Me!razmer
ctl.Height = Me!razmer
f = f + 1
End If
Next
  Îòâåòèòü
 àâòîð: Romiras   (29.01.2007 â 12:17)   ëè÷íîå ñîîáùåíèå
âîò òàêîå ÷óäî ó ìåíÿ åñòü
Sub CtlLenghtError_eng(frm As Form, strWork As String)
Dim ctl As Control
For Each ctl In frm.Controls
        Select Case ctl.ControlType
            Case acTextBox
                If ctl.ControlTipText = strWork Then
                        MsgBox "Data field - " & ctl.ControlTipText & " - " & Chr(13) & _
                        "has more characters than it's need." & Chr(13) & _
                        "Please edit it and try again.", vbCritical, "Process is terminated!"
                        ctl.SetFocus
                        Exit Sub
                End If
        End Select
Next ctl
  Îòâåòèòü
 àâòîð: Explorer   (29.01.2007 â 12:44)   ëè÷íîå ñîîáùåíèå
òî, ÷òî èñïîëüçîâàí ÑåëåêòÊåéñ íà ControlType - ýòî ïðàâèëüíûé ïîäõîä,
òî, ÷òî òèï óêàçàí íå èíäåêñîì à êàê acTextBox - ýòî ïðàâèëüíûé ïîäõîä.
ÿ òàê ïîíèìàþ ïðîöåäóðà ïðîâåðêè äëèíû âûçûâàåòñÿ íà ÷òî-òî âðîäå Form_BeforeUpdate - âîò ýòîãî ÿ íå î÷åíü ïîíèìàþ - çà÷åì äîæèäàòüñÿ ïîêà ïîëüçîâàòåëü íàáúåò äàííûõ â ïîëÿ è ïîòîì îáëîìèòü åãî ñîîáùåíèåì Process is terminated
ÿ òàê ïîíèìàþ, ÷òî íà ïåðâîì æå ïîëå, êîòîðîå íå ñîîòâåòñòâóåò êåéñó ìû ñòàíîâèìñÿ íà íåãî ôîêóñîì è ïðåäëàãàåì ïîëüçîâàòåëþ åãî ïîäðåäàêòèðîâàòü - âîò ýòîãî ÿ òîæå íå ïîíèìàþ - çà÷åì òîãäà áåãàòü ïî âñåé êîëëåêöèè
  Îòâåòèòü
 àâòîð: ÷àñ   (29.01.2007 â 16:06)   ëè÷íîå ñîîáùåíèå
Ýòî ïðîñòî âûäðàíî è ïðåäîñòàâëåíî êàê ïðèìåð...
ïðèìåð òîãî ÷òî ìîæíî ïîèñïîëüçîâàòü , ïåðåäåëàâ ïîä ñâîè íóæäû...
Âñåì îãðîìíàÿ Ñïàñèáà
  Îòâåòèòü
 àâòîð: Romiras   (29.01.2007 â 16:14)   ëè÷íîå ñîîáùåíèå
äëÿ ÷åãî ÿ ýòî èñïîëüçóþ...
íàïðèìåð ñòîèò îãðàíè÷åíèå â 30 ñèìâîëîâ íà ïîëå ÷åëîâåê íàáèâàåò 31 æìåò äîáàâèòü åìó ãîâîðèòñÿ ôèã òåáå â ïîëå ñ äàííûìè íàïðèìåð Äàòà(ÿ ïèøó â êîíòðîëòèï òåêñò ÷òî èìåííî) îøèáêè èñïðàâòå ïîæàëóñòà
ïîåìîåóì ó ìåíÿ íå áåãàåò ïî âñåé êîëåêöèè à äî ïåðâîé îøèáêè..åñëèîøèáêè íåò îñíîâíîé êîä èäåò äàëüøå
åñòü åùå ðåàëèçàöèÿ ñ àêòèâêîíòðîëîì èñïîëüçóþ åñëè ââîäÿò âðåìÿ íå â òîì ôîðìàòå ÷òî íóæíî
  Îòâåòèòü
 àâòîð: ÷àñ   (29.01.2007 â 16:17)   ëè÷íîå ñîîáùåíèå
Õîðîøàÿ øòóêà...
Íóæíàÿ...
Ñïàñèáî...
  Îòâåòèòü
 àâòîð: Romiras   (29.01.2007 â 16:21)   ëè÷íîå ñîîáùåíèå
ëþáèòå õåëï - èñòî÷íèê äàííûõ
îòòóäà ñîäðàííî è àäàïòèðîâàííî
Select Case Err.Number
        Case 3163 'length error
            Call CtlLenghtError_eng(Me, strWork)
            Exit Sub
        Case 3421 'data error
            Call CtlDateError_eng(Me, strWork)
            Exit Sub
End Select
ïðè íàæàòèå íà êíïîêó âûïîëíèòü ò.å. çàíîñÿòñÿ äàííûå â òàáëèöó
  Îòâåòèòü
 àâòîð: Explorer   (29.01.2007 â 16:25)   ëè÷íîå ñîîáùåíèå
íî ïîñëå ýêçèòñàá è âíåñåíèÿ èçìåíåíèé îïÿòü öèêë ïî âñåé êîëëåêöèè è äî ïåðâîé îøèáêè :)))
ïî÷åìó áû íå óñòàíîâèòü îãðàíè÷åíèå ïî êîëè÷åñòâó ñèìâîëîâ ïðÿìî â òàáëèöå? èëè äëÿ ïîëÿ ôîðìû?
  Îòâåòèòü
 àâòîð: Romiras   (29.01.2007 â 16:33)   ëè÷íîå ñîîáùåíèå
íå çíàþ êàê òî òàê ïðèíàëîâ÷èëñÿ...ñòàíäàðòíûå îáðàáîò÷èêè ïèõàþ â ïðîöåäóðû ÷òîáû íå âîçèòüñÿ ñ êàæäûì ïîëåì ôîðìû....
ñîëãàñåí ñ òîáîé ýòî íåìíîãî íå êðàñèâî ïî îòíîøåíèþ ê ïîëüçîâàòåëþ
íî, íåôèê...øîá æèñòü ìàëèíîé íå êàçàëàñü, ïóñòü ïîäáèðàþò ìàêñèìàëüíîå êîëè÷åñòâî ñèìîâëîâ ìåòîäîì ïðîá è îøèáîê
  Îòâåòèòü
 àâòîð: Explorer   (29.01.2007 â 17:30)   ëè÷íîå ñîîáùåíèå
ÈÌÕÎ ëó÷÷å òàê íå ïðèíàëàâ÷èâàòüñÿ - ïîðòèòñÿ ñòèëü...
ÈÌÕÎ ëó÷÷å âñåòàêè â ïîëå òàáëèöû ïðîïèñàòü îãðàíè÷åíèå - åäèíñòâåííûé ìèíóñ - íåâíÿòíûå ñèñòåìíûå ñîîáùåíèÿ, êîòîðûå, ê òîìó æå, çàâèñÿò îò ëîêàëèçàöèè Access/
âîîáùå - ïîëüçîâàòåëÿ íóíî ëþáèòü è íå äåðãàòü ïî ïóñòÿêàì, êîãäà ÿ ÷åïÿòàþ â ïîëå ADMOFF WAREHOUSE SERVICES APR 2007 ÿ ïå÷àòàþ èìåÿ â ãîëîâå âñþ ôðàçó öåëèêîì, è òðàòèòü âðåìÿ íà òî, ÷òîáû çàðàíåå ïîäãàäàòü, ÷òîáû äëèíà ñòðèíãà íå ïðåâûøàëà 35 ñèìâîëîâ, äëÿ ìåíÿ íåñêîëüêî íàïðÿæíî
- êîí÷èòñÿ òåì, ÷òî ÿ ïðîñòî áóäó ïèñàòü WAREHOUSE 07 - è íà âîïðîñû àíàëèòèêà "÷òî çà õðåíü" áóäó îòâå÷àòü - ýòè òóïèöû ðàçðàáîò÷èêè íå ìîãëè ïðåäóñìîòðåòü, ÷òî â ýòîì ïîëå ïîòðåáóåòñÿ áîëåå ïîäðîáíàÿ èíôîðìàöèÿ., ïîýòîìó îáõîäèñü òåì, ÷òî åñòü... àíàëèçèðóéòå ÝÒÎ.
â äèçàéíåðå òàáëèö Access "óìîë÷àëüíàÿ" äëèíà òåêñòîâîãî ïîëÿ òàáëèöû - 50 ñèìâîëîâ... ìîæåò òàê è îñòàâèòü? íåâåëèêà ðàçíèöà 50 èëè 30
  Îòâåòèòü
 àâòîð: ÷àñ   (29.01.2007 â 19:24)   ëè÷íîå ñîîáùåíèå
  Îòâåòèòü
 àâòîð: Explorer   (29.01.2007 â 20:30)   ëè÷íîå ñîîáùåíèå
÷òîáû ñîâñåì áûëî ñìåøíî ðàññêàæó ôè÷ó :)))
â îäíîé þæíî-êîðåéñêîé ïðîãðàììóëèíå, êîòîðóþ äåëàëè àóòñîðñåðû, íà ïîëå ÈÌß_ÔÀÌÈËÈß_ÎÒ×ÅÑÒÂÎ (÷òî ñàìî ïî ñåáå óæå ïîëíàÿ ëàæà) áûëî óñòàíîâëåíî îãðàíè÷åíè÷åíèå ïî äëèíå â 25 ñèìâîëîâ
ïðè ââîäå ìîèõ ÔÈÎÄÀÍÍÛÕ åùå öåëûõ òðè çíàêîìåñòà îñòàþòñÿ, íî äëÿ íåêîòîðûõ ìåíåå ñêðîìíûõ ìîèõ êîëëåã (êàêîâûõ, ïðèçíàåìñÿ, íåìàëî, ïîñêîëüêó êîíòèíãåíò îò Òîêèî äî Áîáðóéñêà) íå õâàòàåò îò 3 äî 10 (!!!) ñèìâîëîâ...
â îáùåì, ðàçíûå âëàäèñëàâû âàëåíòèíîâè÷è ìîãëè íîñèòü ôàìèëèþ íå äëèííåå 2-õ ñèìâîëîâ, ïîñêîëüêó ïî ÒÇ îòäåëà áåçîïàñíîñòè ñîêðàùåíèÿ è èíèöèàëû íå äîïóñêàëèñü
áûëè ðàçíûå ïðåäëîæåíèÿ ïî èñïðàâëåíèþ ñèòóàöèè, îò ñàìûõ ìÿãêèõ - íåìíîãî èçìåíèòü ÒÇ
äî ñàìûõ ðàäèêàëüíûõ - íå ïðèíèìàòü íà ðàáîòó ïåðñîí, ÷üè èìÿ-ôàìèëèÿ-îò÷åñòâî äëèííåå 25 ñèìâîëîâ
(ïî ïîâîäó çíà÷èìîñòè ïðèâåäåííûõ ýêñòðåìóìîâ ó Îòäåëà Áåçîïàñíîñòè áûëî ðîâíî ïðîòèâîïîëîæíîå ïî çíàêó ìíåíèå)
êîí÷èëîñü âñå òåì, ÷òî ýòà ïðîãà áûëà áåçæàëîñòíî ñíåñåíà ê ÷åðòÿì ñîáà÷à÷üèì (ïðàâäà ïîìèìî ýòîé ôè÷è òàì áûë åùå ïÿòîê íå ìåíåå ñ_ò_ðàííûõ çàäâèãîâ) è íîâóþ ïðèëàäó ÿ ëàáàë ñâîèìè ñèëàìè â ïåðåðûâàõ â îñíîâíîé ñâîåé ðàáîòå
êîðåéñêàÿ ïðèëàäà øëà â êîìïëåêòå ñ æåëåçîì, äëÿ êîòîðîãî îíà è áûëà íàïèñàíà è ñòîèëà îíà, ïî ïðåéñêóðàíòó, 2000-00 àìåðèêàíñêîãî ãðèíà
îãðàíè÷åíèå ïî äëèíå ïîëÿ ÒÀÌ ÂÎÎÁÙÅ ÍÀÔÈà ÍÅ ÍÓÆÍÎ ÁÛËÎ - îíî íà ñêîðîñòü ïîëåòà íèêàê è íèãäå íå âëèÿåò... íà îáúåì ÁÄ òîæå ÍÈÊÀÊ - ýòî ïëîñêèé ñïðàâî÷íèê.
ÇÛ
íå ñïðàøèâàé ñêîëüêî ìíå çàïëàòèëè çà ýòó ðàáîòó
è òàê íàñòðîåíèÿ íåò íèêóÿ íèêàêîãî (ïðåäïîñëåäíåå ñëîâî è åñòü îòâåò "ñêîëüêî")
  Îòâåòèòü
 àâòîð: Romiras   (30.01.2007 â 09:09)   ëè÷íîå ñîîáùåíèå
çà÷îò!
ñî÷óâñòâóþ
  Îòâåòèòü
HiProg.com - Òåõíîëîãèè ïðîãðàììèðîâàíèÿ
