тема: Помогите с выгрузкой в Excel
 автор: час   (09.08.2009 в 11:29)   личное сообщение
Public Function Fun_TABLE_IN_XLS(STR_TABLE_NAME As String, To_ROTIN As Boolean, TO_MESSING As Boolean)
' ïåðåáðîñ òàáëèöû â ôàéë Excel
' To_Rotin = true - ïîêàçàòü(îòêðûòü) ôàéë
' To_Message = true - ñîîáùèòü î ïåðåáðîñå
If FUN_Vopros("Âûãðóæàåì â ôàéë Excel? ", vbQuestion) = False Then Exit Function
Dim FILE_STROKA As String ' Ôîðìèðóåìàÿ ñòðîêà
Dim lngPID As Variant ' ïðîñòî ïåðåìåííàÿ
Dim FILE_NAME As String ' èìÿ ôàéëà
Dim FIEL As ADODB.Field ' ïîëå
Dim FIEL1 As ADODB.Field ' ïîëå
Dim rst2 As ADODB.Recordset ' íàáîð çàïèñåé
Set rst2 = New ADODB.Recordset ' íàáîð çàïèñåé
Dim ConnectionString As String ' Ñîåäèíåíèå
Dim ExcelConnection As New ADODB.Connection ' Ñîåäèíåíèå
Dim SQLCommand As String ' Ôîðìèðóåìàÿ ñòðîêà êîìàíä
Dim Cmd As New ADODB.Command ' êîìàíäà
GLB_Patch_REPORT = FUN_OUT_TABLE_String("TUNING_TBL", "Patch", "Ïàïêà_Îò÷åòîâ", "ID")
FILE_NAME = FUN_FILE_NAME_IN(STR_TABLE_NAME, "xls")
FILE_NAME = FUN_Patch_File(GLB_Patch_REPORT, FILE_NAME)
If FUN_FILE_YES_NO(FILE_NAME) = True Then FUN_Delete_File_Name (FILE_NAME)
ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=C:\Excelåtest.xls;Extended Properties=Excel 8.0"
ExcelConnection.Open ConnectionString
rst2.Open "SELECT " & STR_TABLE_NAME & ".* FROM " & STR_TABLE_NAME & " WITH OWNERACCESS OPTION;", GLB_con, adOpenKeyset, adLockOptimistic
If rst2.EOF = False Then ' åñëè òàáëèöà (rst2) íå ïóñòà ïåðåíîñ
FILE_STROKA = ""
' íàçâàíèÿ ñòîëáöîâ (çàãîëîâêè)
For Each FIEL In rst2.Fields
FILE_STROKA = FILE_STROKA & "[" & FIEL.Name & "] TEXT(150), "
Next FIEL
FILE_STROKA = Mid(FILE_STROKA, 1, Len(FILE_STROKA) - 2)
SQLCommand = "CREATE TABLE sheet1 (" & FILE_STROKA & ")"
Cmd.ActiveConnection = ExcelConnection
Cmd.CommandText = SQLCommand
Cmd.Execute
For Each FIEL1 In rst2.Fields 'çíà÷åíèÿ
SQLCommand = "INSERT INTO sheet1." & FIEL1.Name & " VALUES (" & FIEL1 & ")"
Cmd.Execute
FILE_STROKA = ""
Next FIEL1
rst2.Close
Set rst2 = Nothing
ExcelConnection.Close
Set ExcelConnection = Nothing
 автор: ShadowOfSun   (09.08.2009 в 13:28)   личное сообщение
Типа перевел
А в чем вопрос собственно
' переброс таблицы в файл Excel
' To_Rotin = true - показать(открыть) файл
' To_Message = true - сообщить о перебросе
If FUN_Vopros("Выгружаем в файл Excel? ", vbQuestion) = False Then Exit Function
Dim FILE_STROKA As String ' Формируемая строка
Dim lngPID As Variant ' просто переменная
Dim FILE_NAME As String ' имя файла
Dim FIEL As ADODB.Field ' поле
Dim FIEL1 As ADODB.Field ' поле
Dim rst2 As ADODB.Recordset ' набор записей
Set rst2 = New ADODB.Recordset ' набор записей
Dim ConnectionString As String ' Соединение
Dim ExcelConnection As New ADODB.Connection ' Соединение
Dim SQLCommand As String ' Формируемая строка команд
Dim Cmd As New ADODB.Command ' команда
GLB_Patch_REPORT = FUN_OUT_TABLE_String("TUNING_TBL", "Patch", "Папка_Отчетов", "ID")
"Data Source=C:\Excelеtest.xls;Extended Properties=Excel 8.0"
If rst2.EOF = False Then ' если таблица (rst2) не пуста перенос
FILE_STROKA = ""
' названия столбцов (заголовки)
Next FIEL
Cmd.Execute
For Each FIEL1 In rst2.Fields 'значения
Cmd.Execute
FILE_STROKA = ""
Next FIEL1
End If
rst2.Close
Set rst2 = Nothing
 автор: час   (09.08.2009 в 21:31)   личное сообщение
Спасибо за перевод!!!
Кстати в чём причина? какую кодировку и куда засунуть надо?
А вопрос собственно во вставке данных
не могу синтаксически правильно сформировать запрос
об этом и компилятор мне говорит (ВЫ НЕ ПРАВЫ!!!)
 автор: час   (09.08.2009 в 22:12)   личное сообщение
оказалось - вот так
SQLCommand = "INSERT INTO [Sheet1$] (" & FIEL1.Name & ") VALUES ('" & FIEL1 & "')"
 автор: час   (09.08.2009 в 22:16)   личное сообщение
Но теперь другая проблемма
Каждая строчка всё ниже и ниже выводится
 автор: ShadowOfSun   (09.08.2009 в 22:42)   личное сообщение
Глянь на рабочий вариант
Может чем поможет
Option Compare Database
Public Function PrintFormByTemplate(TmplName As String, ID As Long) As Boolean
'Сформировать и вывести форму по шаблону TmplName по записи о работнике с идентификатором ID
'Шаблоны хранятся в папке Templates в каталоге клиента в формате XlS
'Возвращает Истину, если формирование успешно, Ложь - в противном случае
    Dim XL As Object, XLBook As Object, XLSheet As Object
    Dim ClientDir As String, TmplFile As String, OutputDir As String, OutputFile As String, Pos As Long
    Dim Rst As Object, SubRst As Object, StrN As Long
    'Выбрать запись о работнике
    Set Rst = CurrentDb.OpenRecordset("SELECT * FROM [Работники] WHERE ID=" & ID)
    If Rst.EOF Then
        MsgBox "Запись о работнике отсутствует в базе.", , "Ошибка вывода формы " & TmplName
        PrintFormByTemplate = False
        Exit Function
    End If
    'Создать копию файла шаблона для заполнения
    ClientDir = CurrentDb.Name
    Pos = Len(ClientDir)
    Do While Mid(ClientDir, Pos, 1) <> "\"
        Pos = Pos - 1
    Loop
    ClientDir = Left(ClientDir, Pos)
    TmplFile = ClientDir & "Templates\" + TmplName + ".xls"
    If Dir(TmplFile) = "" Then
        MsgBox "Не найден файл шаблона.", , "Ошибка вывода формы " & TmplName
        Exit Function
    End If
    If Dir("C:\Temp", vbDirectory) = "" Then
        MkDir "C:\Temp"
    End If
    OutputDir = "C:\Temp\Персонал.Оперативная статотчетность"
    If Dir(OutputDir, vbDirectory) = "" Then
        MkDir OutputDir
    End If
    OutputFile = OutputDir & "\" & TmplName & " " & Rst![Фамилия] & " " & Rst![Имя] & " " & Rst![Отчество] & "  (таб. номер " & Rst![ТабНомер] & ").xls"
    FileCopy TmplFile, OutputFile
    'Создать объекты Excel
On Error GoTo OLEError
    Set XL = CreateObject("Excel.Application")
On Error GoTo AnyError
    Set XLBook = XL.Workbooks.Open(OutputFile)
    'Вывод в конкретный шаблон
    'Личная карточка работника (унифицированная форма Т-2)
    If TmplName = "Т-2" Then
        '1-й лист
        Set XLSheet = XLBook.Worksheets(1)
        'награды
        StrN = 8
        Set SubRst = CurrentDb.OpenRecordset("SELECT * FROM [_Награды] WHERE [Работник]=" & ID & " ORDER BY ID")
        Do While Not SubRst.EOF
            XLSheet.Cells(StrN, 1) = SubRst![Наименование]
            XLSheet.Cells(StrN, 33) = SubRst![ДокументНаим]
            XLSheet.Cells(StrN, 48) = SubRst![ДокументНомер]
            XLSheet.Cells(StrN, 56) = SubRst![ДокументДата]
            SubRst.MoveNext
            StrN = StrN + 1
        Loop
        'конец награды
    End If
    'Конец личная карточка работника (унифицированная форма Т-2)
    XLBook.Save
    XL.Visible = True
    PrintFormByTemplate = True
    Exit Function
OLEError:
    MsgBox "Microsoft Excel - не установлен.", , "Ошибка вывода формы " & TmplName
    Exit Function
AnyError:
    MsgBox "Неопознанная ошибка.", , "Ошибка вывода формы " & TmplName
    Exit Function
End Function
 автор: час   (09.08.2009 в 22:49)   личное сообщение
Спасибо!!! ShadowOfSun за поддержку.
ФУУУУУххххххх 2 дня муружило
 автор: час   (09.08.2009 в 22:46)   личное сообщение
Оказалось всё вот так:
Выгрузка данных таблицы из MS Access без установленного на машине MS Excel.
Особая благодарность osmor_у
Dim DATA_STROKA As String ' Формируемая строка
"Data Source=" & FILE_NAME & ";Extended Properties=Excel 8.0"
FILE_STROKA = ""
'' названия столбцов (заголовки)
Next FIEL
Cmd.Execute
DATA_STROKA = ""
FILE_STROKA = ""
If Not rst2.BOF Then rst2.MoveFirst
'SQLCommand = "INSERT INTO [Sheet1] (" & FIEL1.Name & ") VALUES ('" & FIEL1 & "')"
'INSERT INTO [Sheet1$] (F1, F2) values ('111', 'ABC')
Do While Not rst2.EOF ' заполняем
If NZVB(FIEL1) <> "" Then
DATA_STROKA = DATA_STROKA & "'" & FIEL1 & "', "
DATA_STROKA = DATA_STROKA & "'-', "
FILE_STROKA = FILE_STROKA & FIEL1.Name & ", "
Next FIEL1
DATA_STROKA = Mid(DATA_STROKA, 1, Len(DATA_STROKA) - 2)
SQLCommand = "INSERT INTO [Sheet1] (" & FILE_STROKA & ") VALUES (" & DATA_STROKA & ")"
'MsgBox DATA_STROKA
'MsgBox FILE_STROKA
Cmd.Execute
DATA_STROKA = ""
FILE_STROKA = ""
rst2.MoveNext
Loop
rst2.Close
Set rst2 = Nothing
If TO_MESSING <> 0 Then Call MsgBox("Готово!!!", vbInformation)
If To_ROTIN <> 0 Then lngPID = Shell(Mid(Get_Wind_Patch, 1, 3) & "Program Files\Internet Explorer\iexplore.exe " & FILE_NAME, 1)
 автор: час   (09.08.2009 в 22:51)   личное сообщение
34 Кб.
Результат таков:
 автор: час   (09.08.2009 в 22:52)   личное сообщение
52 Кб.
таков:
14 Кб.
и таков:
 автор: час   (09.08.2009 в 22:54)   личное сообщение
осталось в dbf и в mdb
Кстати как в dbf выгрузить таблицу MS Access
У кого нить есть функция???
 автор: ShadowOfSun   (09.08.2009 в 22:57)   личное сообщение
Все хорошо, что хорошо кончается
Кроме пива
 автор: час   (09.08.2009 в 23:04)   личное сообщение
Пиво тоже хорошо кончается - струёй в унитаз - КАЙФ!!!!!!
