тема: MS Project или диаграмма Ганта
 автор: kot_k_k   (14.08.2009 в 12:48)   личное сообщение
   to: osmor   (14.08.2009 в 12:18)
Спасибо!!!
без бутылки не разберешься!!!
Может пользователей пристрелить,так быстрее будет и проще
 автор: osmor   (14.08.2009 в 12:18)   личное сообщение
   to: osmor   (14.08.2009 в 12:13)
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=vba%20msproject
 автор: osmor   (14.08.2009 в 12:15)   личное сообщение
и еще
"Mr. Anderson" <vedder@techie.com> wrote:
>Hi,
> Does anyone know how to extract values from a Gantt chart in MSProject
and
>manipulate those values in VB6?
>Regards,
>A
Hi
You can reference MSProject with VB6
'Private WithEvents mobjProject As prjMSProject.clsProject'
Here is some sample code for MSProjects object model
Option Explicit
'Events
Public Event GenError(strMessage As String, intSeverity As Integer)
Public Event ProjectReady(strProjectPath As String, intUserID As Integer)
'Our Microsoft Project Object
Private mobjProject As MSProject.Application
'And of course we require a connection
Private mobjConnection As ADODB.Connection
'Enum's
Public Enum prjRec
prjTimeLineInfo
prjSytem
prjMileStones
prjResource
End Enum
Private Function mCreateMSProject() As Boolean
On Error GoTo Err_Handler
'First for speed we'll attempt to use what's there
Set mobjProject = GetObject(, "MSProject.Application")
Let mCreateMSProject = True
Exit Function
Err_Handler:
'Ok it's not there so reset the error object
Err.Clear
On Error GoTo Err_Failure
'And we'll instantiate a new object
Set mobjProject = CreateObject("MSProject.Application")
Exit Function
Err_Failure:
'Well we tried and Failed
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to instantiate Project -" &
Err.Description, vbExclamation)
Let mCreateMSProject = False
Private Function mOpenConnection(ByVal vstrConnect As String) As Boolean
'Set our Error Handler
'Set our new Connection
Set mobjConnection = New ADODB.Connection
'Open it
Call mobjConnection.Open(vstrConnect)
Let mOpenConnection = True
Exit Function
Err_Handler:
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to open Database -" & Err.Description,
vbExclamation)
Let mOpenConnection = False
Private Function mOpenTemplate() As Boolean
Dim strPath As String
Dim rsRec As Recordset
'Set error handler
'Ok retreive our Template file location
Set rsRec = mOpenRecordset(Replace(mReturnSQL(prjSytem), "*P*", 3), adOpenForwardOnly)
Let strPath = rsRec("xsysParamValue")
mobjProject.FileOpen (strPath)
Let mOpenTemplate = True
Exit Function
Err_Handler:
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to open Template -" & Err.Description,
vbExclamation)
Let mOpenTemplate = False
Private Function mOpenRecordset(ByVal vstrSQL As String, ByVal vintType As
CursorTypeEnum) As ADODB.Recordset
'Set Error Handler
Set rsRec = New ADODB.Recordset
'Well let's open a recordset
Call rsRec.Open(vstrSQL, mobjConnection, vintType)
Set mOpenRecordset = rsRec
Set rsRec = Nothing
Exit Function
Err_Handler:
'Big bad error
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to open Record Set -" & Err.Description,
vbExclamation)
Call Err.Raise(Err.Number, "mOpenRecordset", Err.Description)
Private Function mReturnSQL(ByVal vintRec As prjRec) As String
Select Case vintRec
Case prjRec.prjMileStones
Let mReturnSQL = "SELECT * FROM tttlmTimeLineMilestone WHERE
ttmlTimelineID=*T*"
Case prjRec.prjResource
Let mReturnSQL = "SELECT * FROM tvrscResource WHERE ttmlTimelineID=*T*"
Case prjRec.prjSytem
Let mReturnSQL = "SELECT xsysParamValue FROM txsysSysParam WHERE
xsysParamid=*P*"
Case prjRec.prjTimeLineInfo
Let mReturnSQL = "SELECT * FROM tttmlTimeline WHERE ttmlTimeLineID=*T*"
Case Else
Call Err.Raise(999, "mReturnSQL", "Invalid SQL Requested")
End Select
Private Function mSaveFile(ByRef rstrPath, _
ByVal vlngTimeLineID As Long) As Boolean
'Save the Template we have open
'The Path will be returned in rstrPath
Dim strFileName As String
Dim strSQL As String
'Set Error handler
'Need to retreive the Project Name
Let strFileName = mOpenRecordset(Replace(mReturnSQL(prjTimeLineInfo),
"*T*", vlngTimeLineID), adOpenForwardOnly)("ttmlName")
'Now save it with this Name
mobjProject.FileSaveAs (rstrPath & strFileName)
Let mSaveFile = True
Exit Function
Err_Handler:
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to Save Project -" & Err.Description,
vbExclamation)
Let mSaveFile = False
Private Function mPopDocProperties(ByVal vlngTimeLineID As Long) As Boolean
'This is where we populate document properties
Dim rsRecTL As Recordset
Dim rsRecSys As Recordset
Dim objDocProp As DocumentProperty
'Set error handler
'Set SQL
Let strSQL = Replace(mReturnSQL(prjTimeLineInfo), "*T*", vlngTimeLineID)
'Open a recordset for TL
Set rsRecTL = mOpenRecordset(strSQL, adOpenForwardOnly)
'----TIME LINE PROPERTIES
'Try and add property TL_ID
Call mobjProject.ActiveProject.AddProp("TL_ID", msoPropertyTypeNumber,
vlngTimeLineID)
'Project Name
Call mobjProject.ActiveProject.AddProp("TL_NAME", msoPropertyTypeString,
rsRecTL("ttmlName"))
'User
Call mobjProject.ActiveProject.AddProp("TL_USER", msoPropertyTypeNumber,
rsRecTL("xusrUserID"))
'Date Created
Call mobjProject.ActiveProject.AddProp("TL_DATECREATED", msoPropertyTypeDate,
Date)
'Project Start
Call mobjProject.ActiveProject.AddProp("TL_START", msoPropertyTypeDate,
rsRecTL("ttmlStartDate"))
'Project Description
Call mobjProject.ActiveProject.AddProp("TL_DESC", msoPropertyTypeString,
rsRecTL("ttmlDesc"))
'----System Properties (Paths etc)
'Set SQL
Let strSQL = Replace(mReturnSQL(prjSytem), "*P*", 4)
'Open System Table Rec
Set rsRecSys = mOpenRecordset(strSQL, adOpenForwardOnly)
'Server Location
Call mobjProject.ActiveProject.AddProp("TL_SERVER", msoPropertyTypeString,
rsRecSys("xsysParamValue"))
'Set SQL
Let strSQL = Replace(mReturnSQL(prjSytem), "*P*", 5)
'DLL Name
Call mobjProject.ActiveProject.AddProp("TL_DLL", msoPropertyTypeString,
' End With
Let mPopDocProperties = True
Exit_Function:
Set rsRecTL = Nothing
Set rsRecSys = Nothing
Exit Function
Err_Handler:
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to Set Project properties -"
& Err.Description, vbExclamation)
Let mPopDocProperties = False
Resume Exit_Function
Private Function mSyncMilestones(ByVal vlngTimeLineID As Long) As Boolean
Dim objTask As Task
'Set Error Handler
'Set SQL
Let strSQL = Replace(mReturnSQL(prjMileStones), "*T*", vlngTimeLineID)
'Open Recordset
Set rsRec = mOpenRecordset(strSQL, adOpenForwardOnly)
'Loop Through and Add tasks
Do While Not (rsRec.EOF)
'Generates New Task
Set objTask = mobjProject.ActiveProject.Tasks.Add(rsRec("ttlmTitle").Value)
With objTask
.Start = rsRec("ttlmStartDate").Value
.Finish = rsRec("ttlmEndDate").Value
.Text1 = rsRec("ttlmTimeLineMilestoneID").Value
rsRec.MoveNext
Loop
Let mSyncMilestones = True
Exit_Function:
Set rsRec = Nothing
Exit Function
Err_Handler:
'Set Error Msg
RaiseEvent GenError("Error Occured Unable to Sync Project milestones
-" & Err.Description, vbExclamation)
Let mSyncMilestones = False
Private Function mPopResources(ByVal vlngTimeLineID As Long) As Boolean
'Set Error Handler
'Set SQL to retreive Resources
Let strSQL = Replace(mReturnSQL(prjResource), "*T*", vlngTimeLineID)
Set rsRec = mobjConnection.Execute(strSQL)
While Not rsRec.EOF
With mobjProject.ActiveProject
Call .AddResource(rsRec("xusrNAme"), rsRec("xjbtRate"))
rsRec.MoveNext
Wend
Exit Function
Err_Handler:
Err.Raise Err.Number, "mPopResources", Err.Description
Public Function GenerateProject(ByVal vstrConnect As String, _
Dim strPath As String 'This will be the path of the completed Project
File
Dim intUserID As Integer 'Store user to be emailed
'Set basic error handler
strPath = "C:\"
'Ok first we need project
If mCreateMSProject Then
'Open Our Connection
If mOpenConnection(vstrConnect) Then
'Open the Template file
If mOpenTemplate Then
'Save as TimeLine
Call mSaveFile(strPath, vlngTimeLineID)
'Now we set the document Properties
Call mPopDocProperties(vlngTimeLineID)
'Check For existing Milestones
Call mSyncMilestones(vlngTimeLineID)
'Populate Resources
Call mPopResources(vlngTimeLineID)
'Set Our Project to Active
Call mobjProject.ActiveProject.EditProp("IN_USE", 1)
'Save as TimeLine
'Email to User
RaiseEvent ProjectReady(strPath, intUserID)
'Open Template If
'Connection IF
'Create Project IF
mobjProject.Quit
Exit Function
Err_Handler:
'Set Error Msg
RaiseEvent GenError("Error Occured " & Err.Description, vbExclamation)
mobjProject.Quit
'Bail out
Let GenerateProject = False
 автор: osmor   (14.08.2009 в 12:13)   личное сообщение
   to: kot_k_k   (14.08.2009 в 11:24)
Написано конечно у MS
http://support.microsoft.com/kb/895509
 автор: kot_k_k   (14.08.2009 в 11:24)   личное сообщение
   to: osmor   (14.08.2009 в 10:52)
И где про это написано??? Как VB расправляется с Project не выходя из Аксеса???
 автор: osmor   (14.08.2009 в 10:52)   личное сообщение
   to: kot_k_k   (14.08.2009 в 10:29)
Project может выступать сервером автоматизации, т.е. его можно получить с помощью GetObject
т.е. значит можно сделать все что можно сделать в нем самом методами которые есть у объектов Project
 автор: kot_k_k   (14.08.2009 в 10:29)   личное сообщение
Вопрос есть ли нормальный способ загнать таблицу(отчет, запрос) в Проджект для создания там диаграммы Ганта. Или как построить это счастье в Аксесе?
P/S/ нормальный способ - Пользователь нажимает кнопку - работает прога - Открывается Проджект с диаграммой.
