тема: В чем ощибка ?
 автор: Seryoga204   (21.10.2009 в 23:12)   личное сообщение
Подскажите. для перевода чисел в прописные использую данный код
Function MoneyText(Digit0 As Currency, Currenc As String) As String
b.Flag = 0
b.dd = ""
b.Digit = Abs(Digit0)
b.kop = CInt((b.Digit - Int(b.Digit)) * 100)
b.kop2 = CInt((b.Digit - Int(b.Digit)) * 1000)
b.Digit = Int(b.Digit)
b.HungredMillion = Int(b.Digit / 100000000)
b.d = b.HungredMillion * 100
GoSub Subr
b.TenMillion = Int((Int(b.Digit / 1000000) - b.HungredMillion * 100) / 10) * 10
b.d = b.TenMillion
GoSub Subr
b.Million = Int(b.Digit / 1000000) - b.HungredMillion * 100 - b.TenMillion
b.d = b.Million
GoSub Subr
If b.Million <> 0 Then
    b.d = b.Million * 1000000
    If b.TenMillion <> 0 Then
        b.d = b.TenMillion * 10000000
        If b.HungredMillion <> 0 Then
            b.d = b.HungredMillion * 100000000
        End If
    End If
End If
GoSub Subr
    b.d = b.Million
        b.d = b.TenMillion
        End If
    End If
End If
Select Case b.d
    Case 1
    Case 2 To 4:  b.dd = b.dd + "а"
    Case 5 To 20: b.dd = b.dd + "ов"
    Case Else
        Select Case b.d '- Int(b.d / 10) * 10
            Case 0, 1
            Case Else: b.dd = b.dd + "ов"
        End Select
End Select
'-------1000----------
b.Thousand = Int(b.Digit / 100000) - Int(b.Digit / 1000000) * 10
b.d = b.Thousand * 100
GoSub Subr
b.Hungred = Int(b.Digit / 1000) - b.Thousand * 100 - Int(b.Digit / 1000000) * 1000
If b.Hungred >= 20 Then
    b.d = Int(b.Hungred / 10) * 10
    GoSub Subr 'b.d, b.Hungred, b.dd
    b.d = b.Hungred - b.d
    b.d = b.Hungred
    GoSub Subr
End If
b.d = b.Hungred * 1000
GoSub Subr
Select Case b.Hungred
    Case 1: b.dd = b.dd + "а"
    Case 2 To 4
        Select Case Currenc
            Case "USD", "RUR", "UAH", "BYR": b.dd = b.dd + "и"
            Case "грн", "грн0": b.dd = b.dd + "i"
            Case Else:          b.dd = b.dd + "и"
        End Select
    Case 5 To 20
    Case Else
    Select Case b.Hungred - Int(b.Hungred / 10) * 10
        Case 2 To 4
        Select Case Currenc
        End Select
        Case 5 To 20
    End Select
End Select
If b.Thousand <> 0 And b.Hungred = 0 And b.Flag = 0 Then '
    b.d = 10000
    GoSub Subr
End If
b.dd2 = b.HungredMillion * 1000000 + b.TenMillion * 10000 + b.Million * 10000 + b.Thousand * 1000 + b.Hungred * 10
b.d2 = Int(b.Digit / 100) - b.dd2
b.d = b.d2 * 100
b.Hungred = -1
GoSub Subr ', b.Hungred, b.dd
b.d1 = b.Digit - b.dd2 * 100 - b.d2 * 100
Select Case b.d1
    Case 0:
        Select Case Currenc
            Case "USD":        b.GrDop = " долларов "
            Case "RUR":        b.GrDop = " рублей "
            Case "BYR":        b.GrDop = " бел.рублей "
            Case "грн", "UAH": b.GrDop = " гривень "
            Case "грн0":       b.GrDop = " "
            Case Else:         b.GrDop = " " + Currenc + " "
        End Select
    Case 1
        b.d = Int(b.d1):
        b.Hungred = -1
        GoSub Subr 'b.d, 1, b.dd
        Select Case Currenc
            Case "USD": b.GrDop = " доллар "
            Case "RUR": b.GrDop = " рубль "
            Case "BYR": b.GrDop = " бел.рубль "
            Case "грн", "UAH": b.GrDop = " гривня "
        End Select
    Case 2 To 4
        b.d = Int(b.d1):
        b.Hungred = -1
        b.GrDop = " доллара "
        Select Case Currenc
            Case "USD": b.GrDop = " доллара "
            Case "RUR": b.GrDop = " рубля "
            Case "BYR": b.GrDop = " бел.рубля "
            Case "UAH": b.GrDop = " гривни "
            Case "грн":  b.GrDop = " гривні "
        End Select
    Case 5 To 10
        b.Hungred = 0
        b.d = Int(b.d1 / 10) * 10:   GoSub Subr 'b.d, 0, b.dd
        b.Hungred = -1
        b.d = b.d1 - b.d:            GoSub Subr 'b.d, 1, b.dd
        Select Case b.d
            Case 0, Is >= 5
                    Select Case Currenc
                    Case "UAH", "грн": b.GrDop = " гривень "
                    End Select
            Case 1
                    Select Case Currenc
                    Case "UAH", "грн": b.GrDop = " гривня "
                    End Select
            Case 2 To 4
                    Select Case Currenc
                    End Select
        End Select
    Case 11 To 19
        b.d = b.d1
        b.Hungred = 0
        GoSub Subr 'b.d1, 0, b.dd
                    Select Case Currenc
                    End Select
    Case Is > 19
        b.Hungred = 0
        GoSub Subr
        b.d = b.d1 - b.d
        GoSub Subr
        Select Case b.d
            Case 0, Is >= 5
                    Select Case Currenc
                    End Select
            Case 1
                    Select Case Currenc
                    End Select
            Case 2 To 4
                    Select Case Currenc
                    End Select
        End Select
End Select
If b.Digit = 0 Then b.GrDop = "ноль " + b.GrDop
b.Grv = b.dd
'=========================Є®Їi©ЄЁ=================================
b.kk = ""
If Currenc = "USD" Or Currenc = "UAH" Or Currenc = "RUR" Or Currenc = "BYR" Or Currenc = "грн" Or Currenc = "грн0" Then
    If b.kop <> 0 Then
        b.kk = Mid(Str(b.kop), 2)
        If Len(b.kk) = 1 Then b.kk = "0" + b.kk
        If Len(b.kk) > 2 Then b.kk = Mid(b.kk, 1, 2)
        b.kk = "00"
    End If
  If Currenc = "USD" Then b.kk = b.kk + " центов " Else b.kk = b.kk + " коп."
  If Currenc = "USD" Then b.kk = b.kk + "США"
    If b.kop2 <> 0 Then
        b.kk = Mid(Str(b.kop2), 2)
        If Len(b.kk) = 1 Then b.kk = b.kk + "00"
        If Len(b.kk) = 2 Then b.kk = b.kk + "0"
    End If
End If
b.Grv = LTrim$(b.Grv)
b.Grv = UCase$(Mid$(b.Grv, 1, 1)) + Mid$(b.Grv, 2)
MoneyText = b.Grv + b.GrDop + b.kk
Exit Function
Subr: '===============S U B R ======================
'If Currenc = "USD" Or Currenc = "RUR" Or Currenc = "UAH" Or Currenc = "BYR" Then
If Currenc <> "грн" And Currenc <> "грн0" Then
    Select Case b.d
    Case 0: b.ds = ""
    Case 1:
        If b.Hungred = 0 Then b.ds = "один" Else b.ds = "одна"
        If Currenc = "UAH" Then b.ds = "одна"
    Case 2:
        If b.Hungred = 0 Then b.ds = "два" Else b.ds = "две"
        If Currenc = "UAH" Then b.ds = "две"
    Case 3: b.ds = "три"
    Case 4: b.ds = "четыре"
    Case 5: b.ds = "пять"
    Case 6: b.ds = "шесть"
    Case 7: b.ds = "семь"
    Case 8: b.ds = "восемь"
    Case 9: b.ds = "девять"
    Case 10: b.ds = "десять"
    Case 11: b.ds = "одинадцать"
    Case 12: b.ds = "двенадцать"
    Case 13: b.ds = "тринадцать"
    Case 14: b.ds = "четырнадцать"
    Case 15: b.ds = "пятнадцать"
    Case 16: b.ds = "шестнадцать"
    Case 17: b.ds = "семнадцать"
    Case 18: b.ds = "восемнадцать"
    Case 19: b.ds = "девятнадцать"
    Case 20: b.ds = "двадцать"
    Case 30: b.ds = "тридцать"
    Case 40: b.ds = "сорок"
    Case 50: b.ds = "пятьдесят"
    Case 60: b.ds = "шестьдесят"
    Case 70: b.ds = "семьдесят"
    Case 80: b.ds = "восемьдесят"
    Case 90: b.ds = "девяносто"
    Case 100: b.ds = "сто"
    Case 200: b.ds = "двести"
    Case 300: b.ds = "триста"
    Case 400: b.ds = "четыреста"
    Case 500: b.ds = "пятьсот"
    Case 600: b.ds = "шестьсот"
    Case 700: b.ds = "семьсот"
    Case 800: b.ds = "восемьсот"
    Case 900: b.ds = "девятьсот"
    Case 1000 To 999999:    b.ds = "тысяч": b.Flag = -1
    Case 1000000! To 1000000000# - 999
        b.ds = "миллион"
    Case Is >= 1000000000#: b.ds = "миллард"
    End Select
    Select Case b.d
    Case 0: b.ds = ""
    Case 1: b.ds = "одна"
        Rem If b.Hungred = 0 Then b.ds = "одна" Else b.ds = "один"
    Case 2: b.ds = "двi"
    Case 4: b.ds = "чотири"
    Case 5: b.ds = "п'ять"
    Case 6: b.ds = "шiсть"
    Case 7: b.ds = "сiм"
    Case 8: b.ds = "вiсiм"
    Case 9: b.ds = "дев'ять"
    Case 11: b.ds = "одинадцять"
    Case 12: b.ds = "дванадцять"
    Case 13: b.ds = "тринадцять"
    Case 14: b.ds = "чотирнадцять"
    Case 15: b.ds = "п'ятнадцять"
    Case 16: b.ds = "шiстнадцять"
    Case 17: b.ds = "сiмнадцять"
    Case 18: b.ds = "вiсiмнадцять"
    Case 19: b.ds = "дев'ятнадцять"
    Case 20: b.ds = "двадцять"
    Case 30: b.ds = "тридцять"
    Case 50: b.ds = "п'ятьдесят"
    Case 60: b.ds = "шiстьдесят"
    Case 70: b.ds = "сiмдесят"
    Case 80: b.ds = "вiсiмдесят"
    Case 90: b.ds = "дев'яносто"
    Case 200: b.ds = "двiстi"
    Case 400: b.ds = "чотиреста"
    Case 500: b.ds = "п'ятсот"
    Case 600: b.ds = "шiстсот"
    Case 700: b.ds = "сiмсот"
    Case 800: b.ds = "вiсiмсот"
    Case 900: b.ds = "дев'ятсот"
    Case 1000 To 999999:    b.ds = "тисяч"
    Case 1000000! To 1000000000# - 999: b.ds = "миллион"
    End Select
End If
If b.ds <> "" Then b.dd = b.dd + " " + b.ds
Return
End Function
когда пишу например 1,15 преобразуется в Одна 150 кг, а надо Одна грн 15 коп.
 автор: osmor   (22.10.2009 в 11:26)   личное сообщение
Как вызываете функцию?
 автор: Анатолий (Киев)   (22.10.2009 в 11:55)   личное сообщение
Вероятно вы указываете валюту "грн0", чтоб получить "грн", но вместо "грн" указываете пробел.
Например в этом куске (в других тоже):
    Case 1
        b.d = Int(b.d1):
        b.Hungred = -1
        Select Case Currenc
        End Select
А вот окуда берутся килограммы - загадка!
Что вам мешает выполнить функцию в пошаговом режиме и самому проверить?
 автор: snipe   (22.10.2009 в 12:17)   личное сообщение
ага
а еще косяк в функции - выдает одна рублей 15 коп
и там грамматическая ошибка закралась (я не знаю как по украински) по русски миллиард а не миллард
 автор: Seryoga204   (22.10.2009 в 13:57)   личное сообщение
ок уже подправил
 автор: Анатолий (Киев)   (22.10.2009 в 14:32)   личное сообщение
?TypeName(1000000!)
Single
?TypeName(1000000000#)
Double
Зачем вам эти типы? Без "!" и "#" - Long
