| Господа помогите понять строку из кода
stDocName = ChrW(1041) & ChrW(1088) & ChrW(1086) & ChrW(1085) & ChrW(1100) | |
| Засунь код на событие любой кнопки
Msgbox ChrW(1041) & ChrW(1088) & ChrW(1086) & ChrW(1085) & ChrW(1100) | |
| Пишет название "Клиенты"
А что за оператор ??? что он делает??? | |
| присваивает переменной значение "клиенты"
help по ChrW | |
| Добрый вечер. Подтвердите догатку....Этот оператор кодирует буквы. | |
| F1:
Returns a String containing the character associated with the specified character code.
Syntax
Chr(charcode)
The required charcode argument is a Long that identifies a character.
Remarks
Numbers from 0 – 31 are the same as standard, nonprintable ASCII codes. For example, Chr(10) returns a linefeed character. The normal range for charcode is 0 – 255. However, on DBCS systems, the actual range for charcode is -32768 to 65535.
Note The ChrB function is used with byte data contained in a String. Instead of returning a character, which may be one or two bytes, ChrB always returns a single byte. The ChrW function returns a String containing the Unicode character except on platforms where Unicode is not supported, in which case, the behavior is identical to the Chr function.
Note Visual Basic for the Macintosh does not support Unicode strings. Therefore, ChrW(n) cannot return all Unicode characters for n values in the range of 128 – 65,535, as it does in the Windows environment. Instead, ChrW(n) attempts a "best guess" for Unicode values n greater than 127. Therefore, you should not use ChrW in the Macintosh environment.
