| Работа с OpenOffice.org Calc из VBA - Есть примерчик.
http://hiprog.com/index.php?option=com_content&task=view&id=251661586&Itemid=35
А Работа с OpenOffice.org Writer из VBA - Есть примерчик?
В частности - запуск макросов.
(хотя,наверное,аналогично - покрутить надо...) | |
| с write не работал. запуск макросов не делал нигде | |
| есть кое какие материальчики по OOO.org вот например
DEMO.VBS
'The service manager is always the starting point
'If there is no office running then an office is started up
Set objServiceManager= WScript.CreateObject("com.sun.star.ServiceManager")
'Create the CoreReflection service that is later used to create structs
Set objCoreReflection= objServiceManager.createInstance("com.sun.star.reflection.CoreReflection")
'Create the Desktop
Set objDesktop= objServiceManager.createInstance("com.sun.star.frame.Desktop")
'Open a new empty writer document
Dim args()
Set objDocument= objDesktop.loadComponentFromURL("private:factory/swriter", "_blank", 0, args)
'Create a text object
Set objText= objDocument.getText
'Create a cursor object
Set objCursor= objText.createTextCursor
'Inserting some Text
objText.insertString objCursor, "The first line in the newly created text document." & vbLf, false
'Inserting a second line
objText.insertString objCursor, "Now we're in the second line", false
'Create instance of a text table with 4 columns and 4 rows
Set objTable= objDocument.createInstance( "com.sun.star.text.TextTable")
objTable.initialize 4, 4
'Insert the table
objText.insertTextContent objCursor, objTable, false
'Get first row
Set objRows= objTable.getRows
Set objRow= objRows.getByIndex( 0)
'Set the table background color
objTable.setPropertyValue "BackTransparent", false
objTable.setPropertyValue "BackColor", 13421823
'Set a different background color for the first row
objRow.setPropertyValue "BackTransparent", false
objRow.setPropertyValue "BackColor", 6710932
'Fill the first table row
insertIntoCell "A1","FirstColumn", objTable
insertIntoCell "B1","SecondColumn", objTable
insertIntoCell "C1","ThirdColumn", objTable
insertIntoCell "D1","SUM", objTable
objTable.getCellByName("A2").setValue 22.5
objTable.getCellByName("B2").setValue 5615.3
objTable.getCellByName("C2").setValue -2315.7
objTable.getCellByName("D2").setFormula"sum<A2:C2>"
objTable.getCellByName("A3").setValue 21.5
objTable.getCellByName("B3").setValue 615.3
objTable.getCellByName("C3").setValue -315.7
objTable.getCellByName("D3").setFormula "sum<A3:C3>"
objTable.getCellByName("A4").setValue 121.5
objTable.getCellByName("B4").setValue -615.3
objTable.getCellByName("C4").setValue 415.7
objTable.getCellByName("D4").setFormula "sum<A4:C4>"
'Change the CharColor and add a Shadow
objCursor.setPropertyValue "CharColor", 255
objCursor.setPropertyValue "CharShadowed", true
'Create a paragraph break
'The second argument is a com::sun::star::text::ControlCharacter::PARAGRAPH_BREAK constant
objText.insertControlCharacter objCursor, 0 , false
'Inserting colored Text.
objText.insertString objCursor, " This is a colored Text - blue with shadow" & vbLf, false
'Create a paragraph break ( ControlCharacter::PARAGRAPH_BREAK).
objText.insertControlCharacter objCursor, 0, false
'Create a TextFrame.
Set objTextFrame= objDocument.createInstance("com.sun.star.text.TextFrame")
'Create a Size struct.
Set objSize= createStruct("com.sun.star.awt.Size")
objSize.Width= 15000
objSize.Height= 400
objTextFrame.setSize( objSize)
' TextContentAnchorType.AS_CHARACTER = 1
objTextFrame.setPropertyValue "AnchorType", 1
'insert the frame
objText.insertTextContent objCursor, objTextFrame, false
'Get the text object of the frame
Set objFrameText= objTextFrame.getText
Set objFrameTextCursor= objFrameText.createTextCursor
objFrameText.insertString objFrameTextCursor, "The first line in the newly created text frame.", _
false
objFrameText.insertString objFrameTextCursor, _
vbLf & "With this second line the height of the frame raises.", false
objFrameText.insertControlCharacter objCursor, 0 , false
objCursor.setPropertyValue "CharColor", 65536
objCursor.setPropertyValue "CharShadowed", false
'Insert another string
objText.insertString objCursor, " That's all for now !!", false
On Error Resume Next
If Err Then
MsgBox "An error occurred"
Sub insertIntoCell( strCellName, strText, objTable)
Set objCellText= objTable.getCellByName( strCellName)
Set objCellCursor= objCellText.createTextCursor
objCellCursor.setPropertyValue "CharColor",16777215
objCellText.insertString objCellCursor, strText, false
Function createStruct( strTypeName)
Set classSize= objCoreReflection.forName( strTypeName)
Dim aStruct
classSize.createObject aStruct
Set createStruct= aStruct
| спасибо. будем разбираться. | |
