to: час
(23.01.2011 в 22:30)
| | Ничё не стоит  | |
to: час
(23.01.2011 в 22:28)
| | Дядя_фёдор помог
Option Compare Database
Option Explicit
Private Declare Function apiShellExecute Lib "shell32.dll" _
Alias "ShellExecuteA" _
(ByVal hwnd As Long, _
ByVal lpOperation As String, _
ByVal lpFile As String, _
ByVal lpParameters As String, _
ByVal lpDirectory As String, _
ByVal nShowCmd As Long) _
As Long
'***App Window Constants***
Public Const WIN_NORMAL = 1 'Open Normal
Public Const WIN_MAX = 2 'Open Maximized
Public Const WIN_MIN = 3 'Open Minimized
'***Error Codes***
Private Const ERROR_SUCCESS = 32&
Private Const ERROR_NO_ASSOC = 31&
Private Const ERROR_OUT_OF_MEM = 0&
Private Const ERROR_FILE_NOT_FOUND = 2&
Private Const ERROR_PATH_NOT_FOUND = 3&
Private Const ERROR_BAD_FORMAT = 11&
'***************Usage Examples***********************
'Open a folder: ?fHandleFile("C:\TEMP\",WIN_NORMAL)
'Call Email app: ?fHandleFile("mailto:dash10@hotmail.com",WIN_NORMAL)
'Open URL: ?fHandleFile("http://home.att.net/~dashish", WIN_NORMAL)
'Handle Unknown extensions (call Open With Dialog):
' ?fHandleFile("C:\TEMP\TestThis",Win_Normal)
'Start Access instance:
' ?fHandleFile("I:\mdbs\CodeNStuff.mdb", Win_NORMAL)
Function fHandleFile(stFile As String, lShowHow As Long)
Dim lRet As Long, varTaskID As Variant
Dim stRet As String
'First try ShellExecute
lRet = apiShellExecute(1, vbNullString, _
stFile, vbNullString, vbNullString, lShowHow)
If lRet > ERROR_SUCCESS Then
stRet = vbNullString
lRet = -1
Select Case lRet
Case ERROR_NO_ASSOC:
'Try the OpenWith dialog
varTaskID = Shell("rundll32.exe shell32.dll,OpenAs_RunDLL " _
& stFile, lShowHow)
lRet = (varTaskID <> 0)
Case ERROR_OUT_OF_MEM:
stRet = "Error: Out of Memory/Resources. Couldn't Execute!"
Case ERROR_FILE_NOT_FOUND:
stRet = "Error: File not found. Couldn't Execute!"
Case ERROR_PATH_NOT_FOUND:
stRet = "Error: Path not found. Couldn't Execute!"
Case ERROR_BAD_FORMAT:
stRet = "Error: Bad File Format. Couldn't Execute!"
Case Else:
End Select
fHandleFile = lRet & _
IIf(Len(stRet) = 0, vbNullString, ", " & stRet)
to: oleg99
(23.01.2011 в 02:34)
| | вот тут
http://hiprog.com/forum/read.php?id_forum=2&id_theme=8411&page=2 | |
| | Как можно открыть нажатием кнопки другое VB приложение из первого. Есть кнопки ,, МАГАЗИН,, ,, СКЛАД,, ,, ПОСТАВЩИКИ,, . Нажимая на эти кнопки нужно чтобы открывались эти приложения. Я не имею в виду MDI интерфейс. Если можно подробней. Спасибо. | |
